turbo question
turbo question
I want to run a turbo on my b16a it is obd1 and i was wondering if i have to get an engine management system or piggyback ecu afc to get it tuned. or if the stock ecu can be tuned or will work i only want to run about 6 psi of boost with it intercooled? any help would be great thanks.
RE: turbo question
if your only going low boost go with crome, its easier and will run your car perfectly, your going to need to buy a chipped ecu and swap it with the one you have now (after you install your turbo) from there your tuner will just plug in and play with yourfuel system, match it perfectly with your turbo setup,and youll be safetly boostin your way all round town
soldout712
12
10-30-2006 11:05 PM
eg9
05-22-2006 04:43 PM
forrealb50
03-29-2006 07:57 AM
TrailorParkPimp
08-28-2004 12:21 PM
