Turbo help
Turbo help
I recently bought a 4 door civic dx with a ebay xspower turbo kit. Now everything in this car is basically being exchanged. I am wanting to run a garret t3 t4 with a tial 38mm wastegate synapse synchronic bov. Im gonna keep the intercooler thats on it now. Im gonna buy a new pulley system new eagle rods, and head studs. Does anyone know how much power this will get? And how much boost i could run? Its a d16yz with a vtec head. So basically a frankenstein motor. Any suggestions for parts etc would be appreciated.
RE: Turbo help
good rule of thumb is that an engine can withstand 2x the amount of power it has. d16y7 with y8 head 127x2 = 254hp. This is depending on the health of your engine as well. Do a compression test and a leakdown test to figure out it's health.
Power depends on the tune, if you do get it done proffesionally you can get some decent numbers.
Oh if your going to upgrade the rods you should be able to push it a little more. things you can do to help performance; get the head port and polished, edelbrock intake manifold (or stock one ported polished and matched to the head), forged pistons, bigger injectors.
Things Needed: hi flow cat conveter, 2.5" cat-back exhaust, synthetic oil, one step colder spark plugs
Highly recommend: get your ECU chipped or buy one prechipped, tune at a shop with a good standalone system (crome, hondata, uberdata, etc.), wideband, oil pressure, and boost gauges.
You should figure out what hp goal you want first then go from there. Reliable daily driver? or all out track car? Using a cheap turbo setup you prolly shouldn't go more than 200whp but if you upgrade the right parts.. who knows
RE: Turbo help
^ Werd, good advice. To the OP, you metioned rods and head studs. I agree with Live_4it, get pistons and injectors, and at the very least port match the intake and the head. With all that and a good tune youll get pretty good power numbers, and wont loose reliability.
RE: Turbo help
Id go two step colder plugs. But Live was right. If you want, send me a pm or hit me up on aim ScrewtleMcgootl and ill send you a file of all the stuff i have/am gonna buy for my kit. Its pretty extensive, over a page and a half
RE: Turbo help
heres a pretty damn good list of what to look into, for a good amount of power... and just to inform you, a d16 with eagle rods, forged pistons, new bearings, new water pump, new oil pump / timing belt, and a cam gear can make 400whp with nothing done to the head...
im not trying to brag, but build is about as complete as you can get, (1 1/2 years of info gathering) and its pretty close to what you want, check it out..
and send me an pm and ill help you any way i can, without the help of someone (sov [8D]) i never would have even began my build.
well here it is, whats done to my d series:
heres what im running so far on my 99 ex (120xxx miles).
-Apexi Ws2 catback Exhaust $420
-ebay high flow cat (bolt on test pipe) $$25
-Ebay short shifter& Energy Suspension Bushings $$40
-17" black on crome RSL rims with lexani tires$$725
The Turbo Setup:
-turbo manifold, downpipe, dumptube (sovs setup off his stock d16)$$420
-Garret t3/t40E Ball bearing turbo 50 trim .63 a/r $$975
-AEM Filter (stealing it off my CAI)$00
-Tial 38mm wastegate $$205
-Godspeed Intercooler kit w/ 2.5" piping and bar and plate intercooler$$350
-Tial 50mm BOV $$200
-Fast-Turbo oil line kit w/ oil restrictor $$104
-Glowshift Oil pressure / Boost pressure gauges and gauge cluster $$100
-Oil Sandwhich Adaptor $$35
-obd2b-obd1 conversion harness $$75
-p28 chipped ecu $$175
-Fast-Turbo Vacuum Manifold $$40
-RC550 Fuel Injectors with injector clips (plug and play ftw!) $$279.00 (+ Case of Beer + Pack Of Camels)
-Action2MSSprung clutch (resurfaced stock flywheel) $$375.95
-NGK BRK7E Spark Plugs $$17
-Vacuum Lines
-misc bolts / clamps / vacuum lines / bungs $$60++
goodies to help engine run efficiant:
-Hondata S300 with boost control upgrade $$800
-ARP Headstuds$$200 (d16z6 and y8)
-Walbro 255lph Fuel pump $$103.50
-Weapon Type-RCatch Can $$50.00
-HKS Type 1 Turbotimer & Wiring harness
-BadlanzHPE 2.5" Electric Exhaust Cutout $$175
-Mishimoto radiator / slim fan / radiator hoses $$299.99
-Motorola 2.5 Bar Map Sensor $$38
-AEM Air / Fuel Guageand Bosch UEGO Sensor $$220
-Apocolypse Turbo Oil Pump $$187 (comes ported, shimmed and calibrated)
-Synchro Rings $$115
-obd2b to obd1 distributor adaptor harness $$40
Whats gonna keep my wheels from spinning and on the ground:
-NRG engine damper $89
-Skunk2 Full coilovers $535
-EDT Traction Control Bars $215
-Poly Engine Mount Inserts $31.99
-OBX HelicalLSD $$378
-Blox Racing Front + Rear Camber Kit $$136
-New Differential Bearings & Axle Seals $$101.14
-Anti-Sway Bars
-JDM Motor Mounts $$161.49
D16z6 Head D16Y8 Block: $$3000
Headwork Done-
-skunk2 stage 1 cam
-aem cam gear
-ksm springs / valves / retainers
-3 angle port and polish
-resurfaced deck
-venom intake manifold
-62mm bbk throttle body
Blockwork Done-
-Wiseco 9:5-1 Pistons
-Aluminum Block Gaurd
-Eagle rods
-alluminum Race bearings
-bored and honed
-machined and balanced crankshaft
The Turbo Setup:
-Vacuum Lines
-Anti-Sway Bars
Headwork Done-
-skunk2 stage 1 cam
-aem cam gear
-resurfaced deck
Blockwork Done-
-Eagle rods
-bored and honed
soldout712
12
10-30-2006 11:05 PM
forrealb50
03-29-2006 07:57 AM
TrailorParkPimp
08-28-2004 12:21 PM
