turbo advise on a built GSR
my goal is about 400 whp
my setup
b18c1 block(stock sleeves)
ls crank
81.5mm CP 9.8:1 comp
Scat rods
arp main bolts
arp head studs
i am looking to make roughly 400 whp
i am looking at either the t3/t4 60 trim .63AR or the SC61?
what kind of lag time will i be looking at with the sc61 i already had a 60 trim but broke it.
thanks for any info you can supply
my setup
ls crank
Scat rods
arp main bolts
arp head studs
RE: turbo advise on a built GSR
going with the journal bearing i suppose? throw down an extra $400 and you can cut down on your spool time a little with a BB, and keep boost pressure between shifts better...
just my 2 cents though
