Resistor box for rc injectors?
I'm going to be putting a set of rc 310cc injectors in my d16y8, I was wondering if I will need a resistor box to run them, or if it will be fine without one. it's a 1999, obd2
edit: also installing a greddy e-manage, any tips would be great.
RE: Resistor box for rc injectors?
I'm pretty sure that the injectors i'm going to run are saturated... which are the high impedance injectors. correct me if im wrong... I just need to know if I have the wiring harness for high impediance, I'm not sure of my ecu, whether it's a p2p, p28 or what...
i forget what the OEM injector style is but if you stay as the same style as injector, as in high or low impedience, then you wouldnt need a resistor box, but if you did put the other style in then it would need to be in there or it wouldnt run or it would flood the engine with fuel
sky.
07-12-2008 11:10 PM
