problem: need help fitting turbo w/ AC
i have a treadstone turbo kit and the guy that is installing it for me isn't positive yet, but from looking at things he says he doesnt think it will fit with my air conditioning. The kit is supposed to be AC compatible however.
has anyone here ran into problems with a turbo and AC before? are there little things here and there that need to be tweaked to make it fit?
(sorry I did a search and the search wasnt working for me and this is pretty urgent)
RE: problem: need help fitting turbo w/ AC
that doesnt make sense if its for your engine and A/C compatible it should work however you may have change the orientation of the turbo But the manifold should be compatible. But you could change the orientation of the turbo to make it fit with the A/C hope you get it worked out.
if it's advertised a/c compatible, and can't get it to fit, contact the seller and/or manufacturer.
adjusting the turbo should solve it, if not, you might need a slim condenser fan.
