pix of progress on turbo y7
^when i took out the y7 mani to test fit the z6.
^a lonely SOHC without its best friends exhaust mani and intake mani
^Bastard of an intake mani to walk away from its partner the SOHC
^manis and SOHC are reunited, with a stronger bond then ever called intercooler piping. i really didnt like the 90 degree angle into the y7 mani, however it doesnt work anyways so i will be cuttin and puttin the side mount throttle body z6 in with hopefully no weldin. and i also dont like the blue silicone hose but its all i had.
^the air filter and fancy catch can in the top right corner and my keys
^theres that HKS SSQ BOV!!!
^ just a nice pic
so alls i need left to do is fix the oil leak and i think all i have to do to fix that is just replace the oil pan gasket. and swap in the z6 mani. then all should be good.
hey by the way, the iacv is the only sensor that is different between the y7 and z6 manis right? all the other sensors should just be plug and play?
for more pics clicky: http://www.cardomain.com/ride/745491/1
