octane booster
Old 04-18-2007, 01:10 AM
badb0ybilly's Avatar
Default octane booster
you know the octane booster stuff you can buy at auto parts stores and some gas stations? (the one ive seen most is made by STP)
are those unhealthy for your car at all? and how much performance if any do they add?
Old 04-18-2007, 08:27 AM
Default RE: octane booster
meh, nothing noticable..
Old 04-18-2007, 10:54 AM
riceburner700's Avatar
not worth the money. just spend the extra 10 cents and run premium
Old 04-18-2007, 12:08 PM
ic892003's Avatar
ORIGINAL: riceburner700
+1
Old 04-18-2007, 12:18 PM
the_turtle's Avatar
and get a tune, or reset your ECU, or else thats just worthless
Old 04-19-2007, 12:45 AM
i ALWAYS get premium anyway. i was just wondering if it would actually do anything. lol.
thank you. = )
Old 04-24-2007, 02:20 PM
When you read the label on the Octane booster you will see the claims about how many points you can improve your octane.
What they do not tell you is one point is 1/10 of an octane. Bascially it isa waste of money.
Old 04-24-2007, 02:46 PM
SovXietday's Avatar
Drive what your car is tuned for.
Old 04-26-2007, 09:31 PM
the_turtle's Avatar
also, just a little side note...most of the fuel stuff (aside from the straight up octane booster) is made to clean out your fuel system not only boost octane...that isnt really a waste of money, but something that isnt really needed very often. If my car's motor was worth more, i would use that stuff maybe once a year. But since im building a new motor, that stock y7 can suck it up and keep drinking the dirty ol' 87 grade
Old 04-29-2007, 02:52 AM
More octane= bad for civic
A common misconception is that more octane means faster. More octane means the fuel burns more slowly. In a civic this isn't necessarily a good thing. If the fuel burns too slowly it will cause pre-detonation. The"explosion"in the cylinder will happen as the piston comes back upfrom bottom dead center and the burning fuelrams into the piston.You ideally want the lowest octane you can get away with.. In a civic's case 87... every once in a while premium to burn out old carbon build up.
Quick Reply: octane booster
