Nitrous Jetting question???
I bought a NX wet kit (used) it came with a 22 and 32 jet, im running the 22 in the fuel and 32 in the nitrous. Any idea what shot this would be, i cant figure it out!! Im running a 2002 civic ex with a d17a2 if that helps anything.
RE: Nitrous Jetting question???
when i bought it i was told it was between a 50 and 60, i wanted a exact number. He had it dynoed in his car. i wanted to know the exact shot because i may by alternate jets. and yes, nitrous in the 7th gen is AWESOME.
http://ny-trex.com/calculator.php
there is my answer im running a 46 shot....and running rich on fuel....im gong to upgrade to run a 55 or 60. Mobsta, what are you running on bottle psi, im running a constant 900...what shoul i be aiming for.
NX recommends 1000psito 1050psi. ZEX recommends 900 to 1000psi. I haven't hit the track with my new setup yet but I'm going to be aiming for 950psi starting then see what my plugs tell me. You need to get a bottle heater because too rich can be just as bad if not worse than too lean if you go way rich. Fuel gets trapped under the compression ring, ignites the next stroke, destroys the rings, oil gets in combustion chamber, oil + nitrous + fuel + spark = half a piston left, scared bore. Get a new set of plugs and start checking them after a few pulls with the nitrous.
You have to pull them right after a run, driving it home then reading them isn't going to give you the full story. Do a pull, shut the car off right after you snap off the throttle, pull over and check the plugs.
Detonation mostly. Crystal looking specs being the worst, if you have them you need to pull timing ASAP. Small black speckles on the ceramic are minor preignition, so try to add some more fuel or pull a degree of timing or so.
I'm assuming you're running colder spark plugs, but if you're not you need to find the line on the heatstrap. If you can't find it, you're probably running too hot of a plug.
