nitrous
nitrous
ok i have a 99 coupe with the b18c5 swap. and i am putting on nitrous on it and i was wondering what company and how big of a shot to put because it has 11.1/1 compression. i was think nitrous express 75shot?
RE: nitrous
Do a compression test to make sure your engine can handle it. I guess which company's system to use would be just the opinionated. I like ZEX because of their nitrous control units. Start off with a 35 shot and a wideband o2 sensor then up can up the hp from there. I have heard of some people running up to a 100 shot on a stock engine but I wouldn't go over a 75shot.
RE: nitrous
Research it and see what other b18 drivers are using. A 75 shot on a stock b18 block seems like a bit much for repetative use. 35-50 max to be safe but a wideband will let you know how far you can take it with a good tune. Have you decided if you want to run a wet or dry shot yet?
RE: nitrous
my engine is brand new just did the swap like 1 month ago. nobody has a b18 around here they are all b16 or k20 and there is like 2 h22s. my friend is running a 75 shot on a stock b16sir2. i will only be running it maybe once a week and i will use it for track use only really unless someone messes with meand i was gonna go wet
RE: nitrous
actually dry is safer IMO if you have a fuel controller and injectors that can handle it. With a wet kit you have to run a fuel line which is just one more thing to possibly malfunction. If that fuel doesnt come on with a large injection of nitrous and no fuel to compensate you are screwed.
