need more boost
need more boost
now that i have gotten over my coolant problem, i have been able to really push the car. but because my turbo is so big (T3/T4-.60 ar) and high altitude (6500 feet) i only make about 3.5 pounds at 4500 rpm. i would like about 7 pounds at 3500 rpm. i'm thinking of getting smaller turbo housing, maybe T3, and a manual boost controller. what else can i do?
RE: need more boost
what fuel are you running. meaning is it the stock fuel system or injectors,fuel controller,ecu tunning or none of the above? 2000SI is right get the wastegate and boost controller and if you want it to spool faster get a smaller turbo. you may not be making enough exhaust gas pressure to spool the big turbo.
tilstad
04-01-2006 02:37 PM
