The myth of low CR with high boost
#21
RE: The myth of low CR with high boost
d-series rods are like twigs they are no bigger than my finger.and they snap like twigs.trust me,i now have a b18a as aresult of them.just keep the boost low (6-8lbs.)and have a reliable boost controller.and dont street tune, dyno it,its fragile
#22
ORIGINAL: StinkBOMB
Is 12,000 miles a fair estimate? Or am I underating stock internals on a K series motor?
if i'm correct, you are definitely underestimating the k's internal's. I'm not sure what trim, but i've seen a mid-500hp boosted setup on stock internals at over 2 bar, and it could handle that, but it's not recommended for a dd, or reliability with that setup.
#23
i know im gonna get some laughs for this one but its for a friend and he's not trying to do much right now....
1.5L SOHC
stock internals
upgraded fuel injectors
boost controller
no intercooler (for now)
how much boost will be safe on this engine? 6-8 psi?
thanks guys.....
1.5L SOHC
stock internals
boost controller
thanks guys.....
#25
ORIGINAL: stubAdub
1.5L SOHC
stock internals
boost controller
thanks guys.....
1.5L SOHC
stock internals
boost controller
thanks guys.....
Read the FAQ sticky of this section. You'll find "psi" or "lbs" doesn't mean squat.
Try a DSM T25, get an intercooler, and use a Z6 head/IM//ECU/etc. Check out a HF/CX/STD manfiold on homemadeturbo.com also. Keep fuel (premium) around 12:1and run conservative iginition timing. It should be good for ~200hp.
#27
ok just to make sure i understand you all. if your want to take a stock n/a motor and boost it and still have it as a dd, for relability and safety, it is good to lower the cr. so after you have a complete turbo kit, plans for a good tune, what would be the easiest way to lower your cr and how much lower would it have to go. i don't know alot on this subject just trying to fully understand every aspect of boosting before i even turn the first nut to do it.
#29
now before i ask this no one please give me the you don't even need to begin boosting your car speech cause i'm not. i'm just learning all i can so that when the time does come to boost it i am well imformed. so now i'll bring on the newbieness. what exactly are dished pistons and how will they low the cr?
