max boost on a d16?
RE: max boost on a d16?
you could bolt whatever turbo you wanted onto your d16 as long as you have the correct manifold. I wouldnt look at psi but the amount of power your gonna make. seams about 220whp is the limit for a stock d16
well technically any turbo off of any car can work on your Civic, just takes a little work/fabrication. But common turbo's at t3/t4, t25, t28, etc.....smaller to medium sized turbos work well since our cars wont spool up big diesel turbos hardly at all, and barely make any power. A turbo out of a 760 might work, just find some specs on it's size and then we can help you even more.
In the meantime, read https://www.hondacivicforum.com/m_400323/tm.htmand https://www.hondacivicforum.com/m_414008/tm.htm. Those will get you started.
TheBest
08-07-2012 08:04 PM
