Good bye higher compression
![Default](https://www.hondacivicforum.com/forum/images/icons/icon1.gif)
Well when a turbo is to large to be spooled in a timely maner then n2o becomes helpfull, you would need to be running a gt42 or larger though at above 20psi which will require a full detailed build anyways.
ORIGINAL: Marty
ORIGINAL: riceburner700
what motor is it on?
As it sits right now it's closer to 185hp and 185tq @ 6,000rpm and redlines at 7,150rpm
The turbo I am looking at is for the Focus, but some Escort guys are using it too.
ORIGINAL: eyeh8hondas
2.0ltr DOHC 16valve ZETEC from a 2000 Merc Cougar, same engine in the Focus, similar to the Escort too. 130hp @ 5,750rpm and 130tq @ 4,250rpm redline @ 6,950rpm stock specs.
Why is it all the Ford guys *have* to have nitrous.
I am posting on a Honda Forum because I want to.
I did not come in here and start bashing Hondas.
I just like to see what the Honda Boys are doing.
I do not have to have nitrous, I want nitrous. I've done everything else except a bottom end build, so next step is turbo and nitous.
I have seen your other post and fully understand where you are coming from. But whats with the screen name?
ORIGINAL: drbyers
i predict you're going to have a big hole sticking out the bottom of your block eventually.
