external wastegate problems
RE: external wastegate problems
while im waiting on the camera i have another question. i still have the stock ecu and im wondering just how much boost is expected out of this. i know it wont be much but i would expect a little. anybody got an answer for me. i would really appreciate it!
ORIGINAL: riceburner700
11psi before the ecu will throw a CEL
??????Forget a CEL, thats just not safe for your motor. You try to do a full throttle run on stock injectors and a stock ecu and see what happens. Your just asking for your S##t to explode. Why do you think greddy throws the blue box piggyback with their 6psi kit?? CEL has NOTHING to do with it, its about your injectors and duty cycle. F the MAP sensor, youll blow your motor from overloading the injectors before damage is caused from throwing a CEL.
I know its gonna run lean with stock injectors and ecu mapping, if he was to run stock everything he would be max about 2psi and that would be pushing it. i was just mearing stating if he was using like some 450's and an afc hack
11psi can be done on a chipped and tuned ECU or the VAFC because it has at least fuel settings for that area.
Nail I3unny
12-28-2005 05:56 PM
