do i need an intercooler?
Old 02-13-2008, 02:33 PM
FastCat's Avatar
Default do i need an intercooler?
i am planning on putting a turbo on a d16y8. stock internals. what is the highest psi i can run aturbo at without damaging my turbo?
Old 02-13-2008, 02:41 PM
bakertime's Avatar
Default RE: do i need an intercooler?
Try searching and checking out some articles. If you spend enough time, I'm sure you can find your answer and much much more.
Just a heads up, if you're looking for max PSI...you're motor would probabaly blow before you turbo did.
Old 02-13-2008, 05:28 PM
StifflersMom's Avatar
Cat Fuсker
no, you don't need an intercooler, but you do want one. A certain level of pressure is not going to damage a turbo, it will damage your motor. The most you should run unintercooled on a T25 is around 4-5 psi.
Old 02-13-2008, 05:50 PM
SovXietday's Avatar
Don't worry about your turbo, it won't have a problem. It's your engine that needs the care.
Old 02-14-2008, 03:13 PM
polo708's Avatar
4-5 lbs of boost? No way...it will handle atleast 7-8 without NEEDING an intercooler if tuned properly and running premium gas.
And like said... dont worry about that turbo. The motor will let you know when you are half way close to hurting the turbo, lol.
Old 02-14-2008, 03:53 PM
Cat Fuсker
ORIGINAL: polo708
at 7-8 psi non intercooled he'll be running crazy EGTs...cats will become a consumable
Old 02-14-2008, 04:11 PM
SovXietday's Avatar
ORIGINAL: polo708
Yeah, more or less. Roto you have to remember that he's got an M45 on his car. He's all about high IATs. [8D] Haha!
Get an intercooler... and really need to do your research.
Old 02-14-2008, 04:27 PM
Cat Fuсker
ORIGINAL: SovXietday
ORIGINAL: polo708
IIRC he's also running water injection...so he's got a chemical intercooler
Old 02-14-2008, 05:26 PM
polo708's Avatar
true I have it... but im at 10 lbs of boost with a roots blower...apples and oranges. A turbo setup on a tuned 4 banger can handle 7-8 in my opinion.
Old 02-14-2008, 07:08 PM
Cat Fuсker
I didn't say it can't, I just said it was unjustifyable stress...I would not want to run all day long with ridiculously high temps... an intercooler can be had for like $80 at a junkyard ($85 in my case) and some pipe for like $30-50 if you don't go fancy and do crush bent...no reason not to do it.
Quick Reply: do i need an intercooler?
