d16 turbo
Old 05-08-2008, 05:01 PM
abdoo's Avatar
Default d16 turbo
i have a honda civic hatch si... some of my friends tell me if i put a turbo on i will more than likly blow my engine if i dont ungrade my pistons and conecting rods is this true?
Old 05-08-2008, 11:21 PM
Live_4it's Avatar
Default RE: d16 turbo
depends on how much you plan on boosting.
Old 05-08-2008, 11:29 PM
arust45's Avatar
Your friends are smart. If you turbo your motor with your current knowledge of supercharching, you will blow your motor, research.
________
Weed Bubblers
Old 05-09-2008, 04:41 PM
abdoo's Avatar
i have been researching it but i was wondering with a small enough boost i can servive. lol
Old 05-09-2008, 08:51 PM
Do a compression check first. If everything checks out, and your motor runs well, it should be able to handle 6-8 lbs of boost.
Old 05-09-2008, 11:43 PM
arust45's Avatar
Your pistons and connecting rods can most likelycan handle 6-8lbs on a small turbo, but it is enough boost to lift your head and blow the headgasket even on the healthiest of engines. If your engine is in good condition after compression/leakdown testing, order yourself arp headstuds and a headgasket from your nearest honda dealer before boosting. Look into a t3, t25, or equivalent sized turbo, well suited for the size of your motor. You'll also need a high performance clutch, because the stock clutch will wear down to nothing fast. Good luck on your research.
________
Avandia recall
Old 05-11-2008, 12:22 AM
didder's Avatar
t25 turbo is going to be a torquier turbo setup which will be harder on your rods. and it will have a lot less top end power, but it will be a pretty fun dd'er
t3/t4 turbo is more suitable imo, boosts around 3600rpm and will net you around 200+whp safely with 8lbs of boost and a good tune. headstuds arent a nescessity below 220whp, but always the safe bet, plus there easy to install.
hell, sov has his ek coupe boosted to 220whp on 8lbs for 6 months on a bone stock d16y8, and his head never lifted, you "should" be fine as long as your compression checks out, id say keep the numbers within 5-7% for 8 pounds
Old 05-11-2008, 12:49 PM
abdoo's Avatar
its a none v tech does this make a difference?
Old 05-11-2008, 01:39 PM
TheShimster91HB's Avatar
Every honda motor is "none v tech"... Vtec, on the other hand, gives some people trouble in the tuning department.
Old 05-11-2008, 02:16 PM
abdoo's Avatar
ok good. thank you
Quick Reply: d16 turbo
