Chipped p28
RE: Chipped p28
ORIGINAL: aryiman98civic
sov i didnt know you knew how to tune, how did you learn?
dfdon I overwrote the file so the one you downloaded is the right one. Like I said it should start, but I know that my basemap didn't start the first time but either way it should be ready for just a street tune so your tuner can figure out the fuel and you'll be able to boost from there.
Edit: Like I said, if it starts let it warm up before you drive it around! Reason being is that I have it set to adjust fuel via your stock O2 sensor but the chip is set to read directly off the map after you pass 7* of vacuum. In other words, once the car enters closed loop it will run around 14.7 AFRs but anything about 7 may or may not be off.
boreddude564
01-26-2011 08:12 PM
traitorzxiong
14
08-15-2007 08:30 AM
