boost controller
![Default](https://www.hondacivicforum.com/forum/images/icons/icon1.gif)
im installing my turbo kit tom it is an ihi out of a mx6 i was told it is set to 7psi from the factory i dont want to push it on my d16 i heard that a manual boost controller cant lower my boost under what the waste gate is set for is this true? i would like to run 3-5 psi on a daily basis mabey the 7-8 some weekends if i go to the track plz help
the only way u would be able todo that is by takin off the turbin housing and welding the internal wastegate hole closed so it wouldnt /leak, the only other alternative would be to either convert to an external setup with a garret t-3 or t-3/t-4.
the only way of adjusting the wastegate on an interal WG is to adjust or pin the wastegate actuator closed so it wouldn open
allstock
03-25-2006 04:25 PM
nemesis08
11-13-2005 05:25 AM
