b16 with spray?
RE: b16 with spray?
Do some research.A 75-100 will be pushing it but it is do-able, you will need to upgrade your fuel pump for a 100 shot though. Do a wet and dry compression test and make sure you are not burning any oil before you spray or you will have big problems.Before you even buy nitrous I would suggust just buying i/h/e because that will help you get the most out of your nitrous kit.
