9 psi
RE: 9 psi
Depends on the turbo, the fuel management, the tune, and alot of other things. A built engine with a properly sized turbo will blow on 5psi with bad equipment but a stock engine will be fine with a decent sized turbo at 15psi with good equipment and a good tune.
RE: 9 psi
im pretty sure if u use turbo edit u dont need the VAFC besides the VAFC is crap, id use hondata S200 w.boost option over that crap. Or go to a tuner and see if u can get him to use Uberdata or Neptune.
RE: 9 psi
You'll be fine if you have a really good tune. And why would you use a VAFC if you're going to be tuning with TurboEdit? You need to do a little reading up on things...anyway, like md420 said, a thicker head gasket would be a good...but you should be fine at 9psi and just a good tune. With a thicker head gasket, you might could run around 10 psi as long as you have it tuned good.
