'86 honda civic 25R....can it handle turb
Old 04-21-2006, 05:26 PM
epix's Avatar
Default '86 honda civic 25R....can it handle turb
ok this is what i want to know before i make any costly mistakes....can my civic be turb'd, 86 civic 25R....picture as follows too with engine bay...it was green when i brought it...also battery was getting replaced same as some leads for clarification
[IMG]local://upfiles/10099/A6E8EDDECC5F42BA8F41F6DCFEE72B0E.jpg[/IMG]
[IMG]local://upfiles/10099/DFBD26D6EF9E414899CE13E463E87F47.jpg[/IMG]
[IMG]local://upfiles/10099/5CAC341A71944BD1878B3E2E531AF1BE.jpg[/IMG]
Old 04-21-2006, 05:29 PM
epix's Avatar
Default RE: '86 honda civic 25R....can it handle turb
obviously standard at the moment hehe.....but waiting to see if it is worthwhile turb'ing it before replacing standard parts with aftermarket...or replacing whole engine maybe
Old 04-21-2006, 08:27 PM
You should try this paintjob. Sbowers is in the process of doing it and it looks great.
https://www.hondacivicforum.com/m_200328/tm.htm
As far as the turbo, im not an expert but it seems the be the general responce that if you have a healthy engine without leaks or anything then go for it. Or if it has crasy high miles, you could look into a similar motor with less miles or a b series or something. Just depends on your budget.
Old 04-23-2006, 10:26 PM
epix's Avatar
thanks man...i think i will try and see what the results are on the engine and soforth and then decide if its better to get new block or upgrade standard parts.
and thinks for the link.it looks nice. i think im going a better red or blue....
Old 04-24-2006, 10:14 AM
StifflersMom's Avatar
Cat Fuсker
A turbo on a carburated engine....a nightmare
Old 04-24-2006, 05:14 PM
riceburner700's Avatar
yeah dont turbo that motor unless you are 100% sure of what you are doing... drop in like a d16z6 which is mpfi and obd-1 which you can tune really easily and then slap the turbo kit on and tune it and you are on your way...
Old 04-24-2006, 05:19 PM
ef4life's Avatar
yeah, carbs are a pain to turbo and get to run correctly. hks and mugen both made turbo kits for that generation of civic, but they were fuel injected models only. so fuel injection is the best way to run. hasport makes a swap kit to drop a b series in, so get a b18b and put dual webers on it and build it to be a NA screamer, then you would have power and no wiring nightmare
Old 04-27-2006, 01:52 AM
epix's Avatar
there are a current number of engines available b18, b20, d15, b16 all which come with drive train.
thanks for all the help
Old 04-27-2006, 03:16 AM
Marty's Avatar
ORIGINAL: Kolhoznik
WHAT??????????
Noway man
Old 04-27-2006, 08:49 AM
i hate chrome detailed motors...
It'd be rare as **** if you did the project, but like said above, it'd be a pain in the ***...
Quick Reply: '86 honda civic 25R....can it handle turb
