70 shot wet
70 shot wet
ok i can't seem to get a straight answer anywhere so can someone help me out? What do i need to make 100% sure my car will be ok running a 70-75 shot wet kit? I know i need colder spark plugs. Where do i get a compression check done? How do i retard timing on a 7th gen civic?
RE: 70 shot wet
Start with the lowest shot that the kit offers then work your way up to a 75 shot. You do the compression test yourself, go to advance or autozone and rent/buy a tester. Retard timing by either a stand alone management system or there might a piggy back you can use like from msd ignitions. If you are burning oil you can't use nitrous, it will detonate. To be honest though, I don't know if you can put a nitrous kit on a car with a returnless fuel line. You might have to make it a return style fuel system.
WrongfulWright
03-17-2005 10:45 PM
