300 hp!
#23
RE: 300 hp!
ORIGINAL: md420
Main thing will be to run a good amount of fuel to keep cyl temps down
P.s. The only reason I ask is because I don't know, not trying to be antagonistic I promise
#24
RE: 300 hp!
more air = more heat which in turn ='s "knock". This is what kills most performance builds, But the more fuel you add the cooler the temps go in the cyl walls. Now I aint saying to go out and run it pig rich flooding it out or anything but my main point is that if you stay in a good target air/fuel ratio range, pull timing correctly, and do not beat on a engine it will serve you good.
#27
#28
RE: 300 hp!
so would u say a msd boost timing master is a good thing to add cause the guy who is tuning mine said he wanted to add one and i said do it and send me the bill. it does something with retarding the timing or spark. something. anyway i have that and alcohol injection and until i hit boost the alcohol don't kick in. so it gives me all the fuel i need when i need it and i won't be running rich when im not entering boost.
also the stage one will not work. look it up stage 3 and 4 are for boost applications u can pick a stage 4 clutch master on ebay for $333. Dude it just won't hold. not trying to start any fights cause i say it was getting kinda heated in here but, i am 99% it won't hold unless u have some super stage one clutch that no one has heard of and in that case where u get it cause i want one.LOL
#29
#30
RE: 300 hp!
ORIGINAL: 97civicturbo
If you wanna build a car, build it for about 25% OVER what you are going to push it, otherwise you're just asking for trouble.
frontierguy_nc
03-29-2006 02:03 AM
moogs
09-09-2004 06:36 PM
