10lbs safe on stock internals?
Old 09-10-2006, 05:20 PM
redridinhood's Avatar
Default 10lbs safe on stock internals?
I was just looking at the JR stage two upgrade and they dyno sheet said the civic (sohc) only had header, JR intake, and cat back with the stage two upgrade on ten lbs boost. Is this safe on the stock internals with maybe arp head studs or is this going to kill motor life quick?
Old 09-10-2006, 06:03 PM
arust45's Avatar
Default RE: 10lbs safe on stock internals?
depends on turbo/tune. what are your power goals?
________
California Medical Marijuana Dispensary
Old 09-10-2006, 06:13 PM
i was just looking on the jackson racing site and the civic supercharger with just those mods to the car was running ten lbs on stock internals making around 200 hp and 160ft lbs of torque and i was just wandering if the stock motor was up to 10lbs of boost
Old 09-10-2006, 06:22 PM
arust45's Avatar
oops i didn't mean to write turbo. Anyways a stock d-series engine could handle 200 whp safely. That's my goal when i get my turbo. At least get a decent tune. thats the last place you wanna go cheap if you're worried about longevity of your motor.
________
Web Shows
Old 09-10-2006, 07:05 PM
dfdon's Avatar
arust is right your motor life will depend on the quality of tune
Old 09-10-2006, 07:17 PM
k that makes sense just didnt know if it would need a tune cause this is what the stage two upgrade comes with
http://jacksonracing.com/Shop/ViewPr...eIndexID=41633
Old 09-10-2006, 07:55 PM
riceburner700's Avatar
if your motor checks out good on a leakdown or compression test than you should be golden for 10psi with some arp's and a good tune
Old 09-10-2006, 08:54 PM
^^^+1 What he said
Old 09-10-2006, 10:48 PM
SovXietday's Avatar
If you're going to push 10psi on a JRSC I'd looking into either meth injection or the LHT intercooler setup. Otherwise you'll need to put pistons in or you'll probably melt the block.
M45 at 10psi normally sees 250+ IAT temps, 300 even in the summer. Not a good thing.
Old 09-10-2006, 11:58 PM
finalimpact's Avatar
^^^^^^ werd this is why i havnt bought a new pulley for my jrsc. until i have either water/meth injection or the lht intercooler set up i will stay at my current 5.5 psi. and either way you look at it, upgrades to the engine in forms of FI, nitrous, cams, compression etc will lead to more wear and tear regardless of the tune.
Quick Reply: 10lbs safe on stock internals?
