wont start when warmed up!!
Old 02-05-2005 | 08:59 AM
92 Dohc vtec civic's Avatar
Default wont start when warmed up!!
I have a 92 civic with the 1.6 Dohc vtec engine, the car starts fine when cold but when the car is warmed up and if you turn the engine off for a few minutes (at a petrol station etc) the car will start then stall, if you try again straight away it just turns over on the starter motor....If you leave it for a couple of minutes and try again it will start...
I've so far replaced the spark plugs, HT leads and the dissy cap and the problem is still there..
I'm a bit stuck and don't know where to start looking for the problem so any help would be great....
Old 02-05-2005 | 12:59 PM
Kappa22's Avatar
Default RE: wont start when warmed up!!
Fuel pump relay. Happened to me on 3 seperate Civics.
Old 02-05-2005 | 05:15 PM
Thanks for the advice Kappa22, I'll have a look at the relay and let you know...
Old 02-07-2005 | 09:54 AM
Blackhatch124's Avatar
yeah thats your fuel pump relay, usually its just as easy as hitting the reset button on it and it works fine but honda wants you to pay a couple hundred for them to fix it
Old 02-07-2005 | 12:38 PM
Found the relay today and spoke to Honda to see how much a new one ones, I was glad I was sat down when he told me!!
These things are expensive for such a small box with switchs in it....
honda_farmboy
10-01-2015 02:05 PM
95turbocivic
06-13-2011 10:14 AM
rTc
06-29-2010 12:39 PM
93civicrush
03-24-2007 10:05 AM
point78
08-22-2006 05:40 AM
Quick Reply: wont start when warmed up!!
