wom wom engine sound help
Old 03-20-2011 | 05:30 PM
Will FITV make the engine stall out (when warmed up)? No.
Bleed the cooling system. If problem persists there are some other checks you can do.
Old 03-20-2011 | 06:45 PM
88MoParCivic's Avatar
Are the RPM's pulsing? or is it just a noise?
Old 03-21-2011 | 02:26 PM
cjy01's Avatar
rpms are pulsing and the car runs for about 5-10 minutes and the car goes to really low rpms and dies a few seconds later. also my fan isnt coming on but it works.
Old 04-12-2011 | 02:31 PM
cjy01's Avatar
update i my car is still reving up and down. Spark plugs have black soot on them. could my timing belt be installed incorrect
Old 04-12-2011 | 05:27 PM
DaOne's Avatar
Originally Posted by DaOne
Did you try bleeding your cooling system?
Did it start doing it after a timing belt change or why do you suspect a timing problem?
Old 04-13-2011 | 03:31 AM
cjy01's Avatar
I changed the timing belt before I put this engine in and I have bleed the cooling system. I also cleaned iac valve. My spark plugs are black with soot on them and my car backfires
runswit2guns
12-11-2011 09:38 PM
cjy01
03-06-2011 03:34 PM
Civic Si 00
02-26-2008 06:22 PM
cinefyl
05-21-2006 12:54 PM
z6 FoRiLLa
09-28-2005 03:28 PM
Quick Reply: wom wom engine sound help
