wom wom engine sound help
Old 03-13-2011 | 01:37 PM
cjy01's Avatar
Default wom wom engine sound help
here is the link to hear the sound please help its a 1994 honda civic vtec
http://www.youtube.com/watch?v=XGlnHIBeE2Y
Old 03-13-2011 | 02:23 PM
DaOne's Avatar
Sounds like its just reving up and down.
Maybe you have air in your cooling system.
https://www.hondacivicforum.com/foru...ad.php?t=41650
Old 03-13-2011 | 02:26 PM
cjy01's Avatar
it cuts off after about 3-5 minutes running could that still be the cooling
Old 03-13-2011 | 02:28 PM
Lewy2k's Avatar
FITV. Clean it and reposition it in the correct spot by screwing the piece inside to where it needs to be. Should fix it.
Old 03-20-2011 | 02:28 PM
cjy01's Avatar
cleaned iac and fitv and still makes that sound
Old 03-20-2011 | 03:03 PM
DaOne's Avatar
Did you try bleeding your cooling system?
Old 03-20-2011 | 03:10 PM
cjy01's Avatar
i did my car runs for a while reving up and down and then about 3-5 mins later it cuts off
Old 03-20-2011 | 03:37 PM
Lewy2k's Avatar
you have to adjust the fitv to the proper specs not just clean it to fix it.
Old 03-20-2011 | 03:39 PM
cjy01's Avatar
how far do i turn it in
Old 03-20-2011 | 03:44 PM
cjy01's Avatar
will the fitv make the car cut off
Quick Reply: wom wom engine sound help
