window wont stay up
window wont stay up
I did a search and found no help, so...
The problem is that you rollthe passenger side windowup and as you drive, it rolls back down about an inch. How can I fix this? Is the track adjustable?
This is on a DX. It has a crank, not a button. I muststress that this is a MANUAL window, not a power window.
RE: window wont stay up
yeah, as mk says, your window regulator likely needs to be replaced. Several years ago, I paid $75 for one from the Honda dealer. You might also consider getting one cheaper from a salvage yard.
I adjusted the tracks and got the window to stay up. It works much better now. All I ended up doing was removing the door panel, loosening three bolts, and moving the window tracks slightly inward.
project5k
06-16-2009 10:35 PM
MistaGlock
17
04-08-2009 05:09 PM
Tealingston
12-31-2008 08:48 PM
