window off track
RE: window off track
Yeah i had problems with my window too (took it apart many many times) well i need a need regulator cause it keeps on popping back out. But if your lucky you just need to undo one screw at the front of the door, and you should be able to get the window back on the rail, then tighten that screw real good
Ya, thankfully just needed to take that bolt off and swing the track back a little. Did you put silicone spray on? I read on almost every thread with window track problems that silicone spray solved repeated problems. Or helped a lot.
97Ej8
04-24-2012 04:56 PM
