Will 215/60/R15 tires fit 92 EX?
It has 205/50/R15 on it now. I know it originally had 185/60/R14, right? I just wanna make sure that the 215/60/R15won't bottom out when I hit a bump or rub when I turn or cause any other problems.
RE: Will 215/60/R15 tires fit 92 EX?
those are huge! if you're lowered then there's no doubt about it, you're gonna have rubbing issues. If you're not lowered they might not bottom out, but you'll most likely have rubbing if you turn real sharp.
and your speedometer reading is going to be 10.6% too slow. when your speedo reads 60mph you will be going 66.4mph
the width you need depends on thewidth of thewheel.most likely you have a 6.5" widewheel. if you do then 205 is the biggest you should use. and the 215 would be too big.
and the sidewall size is definetely too big and you will rub. you might be able to fit a 55, but i would just go safe and stick with what you already have in the 205/50.
ORIGINAL: saiguanas
Alright good to know. Thanks.
I guess there's a reason that discount tire doesn't list them for the plus one sizes.
For the record, I'm not lowered but still I guess I'll stick with what works. There's probably a reason that the previous owner didn't go any wider or taller either.
mr_b
05-10-2015 09:20 AM
runswit2guns
07-29-2011 03:30 PM
RSX_Styling
10-17-2007 10:18 PM
crxguy89
03-23-2005 03:22 PM
