Wierd Car Deck Problem
Ok so my deck finda flew out a lil bit but not all the way out of the socket because I ripped my car down the street. So I went to fix it back in the spot and after i shoved it back in I turned on my car and now the deck isnt working...I even took out the deck to see if it was wired properly and everything is fine and even re-wired to be safe. And I also noticed that my cigarette lighter isnt working either and its plugged in properly because I took out that whole bottom console that has the change pan connected to it and check and everything seemed ok. Any ideas guys?
Yeah when it came loose the wires must have shorted out and blown a fuse. Since the lighter doesn't work either it should be the fuse under the dash. There is also a fuse in the box under the hood labeled "BACK UP" which supplies power to the radio.
Many aftermarket decks will also completely shut down if they detect a short in any of the speaker wires.
