Why am I getting to much gas?
Old 01-10-2008 | 04:53 PM
David_123's Avatar
Default Why am I getting to much gas?
I have recently purchased a 1999 Honda Civic Si. It ran good for two months, then the problems came. It has many extra parts including a turbo and MSD ignition. The problem that I had, was while I was driving down the highway it would bog a few times then die completly. Somebody told me the MSD probably went bad. I replaced the MSD ignition back to stock. Then it wouldn't start.I checked the spark plugs realized they were really wet.I found out it was getting to much gas. If I unplugged the injectors it would almost start with a little starting fluid. But i don't know why it would be getting to much gas. Please help.
Old 01-10-2008 | 05:09 PM
Mr Mobsta Man's Avatar
Default RE: Why am I getting to much gas?
You said it had a turbo so it has some sort of aftermarket engine management, do you know what it is? ex: Emanage, chipped ecu, standalone?
Old 01-10-2008 | 05:13 PM
JETSPEED333's Avatar
it's not getting too much gas... your seeing the gas on the spark plugs because your having incomplete combustion.
this still actually sounds like a spark issue to me. you need to check for suffecient spark from each plug/wire... as soon as you have sufficient spark you will begin to have amore complete combustion in the chamber and not see fuel left behind like your seeing now.
i would suggest replacing your ignition parts with msd parts again if your running turbo because with added pressure in the combustion chamber, it makes it a lot more difficult for the spark to bridge the gap.
good luck!
Old 01-10-2008 | 05:30 PM
David_123's Avatar
No I am not sure What kind Of ecu it is but I still had the stock one in it and tryed it. Had the same problem so i didn't think it was the ecu. would u still think it would be the ecu?
Old 01-10-2008 | 05:34 PM
David_123's Avatar
I have checked the spark And it looks good. Also I have talked to people that said it should be ok not have the MSD. Do u think I need it?
Old 01-10-2008 | 05:37 PM
it's not the ecu... think about it, if the msd ignition had a failure problem....and you havn't fixed it since(hasn't run right).... you still have an ignition problem [sm=chairshot.gif]
check for spark.
Honestly I am not good at troubleshooting so I can't help too much but I think you should post everything you know about your setup so someone more experienced than me can help.
Old 01-10-2008 | 05:53 PM
depending on how much boost your running... and what rpm's your getting into would decide if you "really" needed the msd... but believe me, if your modding your car in ways it sounds like you are... msd ignition is a great system to have.
noahyes89
02-18-2008 09:43 AM
Fiirkan
03-10-2007 11:09 PM
dblclutchin
11-14-2006 01:40 AM
dblclutchin
07-04-2006 03:46 PM
Quick Reply: Why am I getting to much gas?
