where to get a knuckle?
Old 06-30-2008 | 11:33 PM
saiguanas's Avatar
Default where to get a knuckle?
Is there another name for the knuckle because I can't find it at autozone or oreilley's. Where is the best place to get one for 92 EX driver's side?
Old 07-01-2008 | 12:47 AM
Default RE: where to get a knuckle?
best place: Honda dealer
But if I were you i'd head to the junkyard and pull a used one off a 92-95 civic. You can get it cheap and it'll work fine.
Old 07-01-2008 | 01:17 AM
saiguanas's Avatar
are all of the models of 92-95 the same?
I did find on some junkyard search databases that they had "EX" and "except EX". Is the EX different?
Old 07-01-2008 | 10:11 AM
I think it has something to do with having ABS. If you have anti-lock brakes, you need the knuckle from an LX with ABS, or an EX with ABS. If you don't have ABS, you need one from a car without ABS. 92-95 will work.
Old 07-01-2008 | 10:14 AM
I like the junkyard idea. Otherwise, here are some potential online OEM sources that will likely be cheaper than the dealership:
http://www.hondaautomotiveparts.com/
http://www.honda-tech.com/zerothread?id=2059889
wjd03
09-01-2009 04:56 PM
hookecho
09-27-2008 02:48 PM
saiguanas
07-06-2008 06:53 AM
SPLAT
07-05-2008 04:13 PM
civicexracer
10-13-2006 03:52 PM
