Where is the ecu ecm on 98 civic lx?
Old 09-30-2011 | 01:59 PM
CarmenDA's Avatar
Default Where is the ecu ecm on 98 civic lx?
Hi again. I don't know why this is so hard to find but I googled it a million times and can't seem to see a picture or a good description about how to get to the ecu or ecm or whatever its called.
I read somewhere that I can see the led light when I turn the key and it flashes some codes. I see nothing.
My car won't start and its driving me nuts. Thanks
Old 09-30-2011 | 02:04 PM
No need for two threads. It's behind the passenger-side kick panel.
Old 09-30-2011 | 02:44 PM
Quasars's Avatar
Thumbs up
^^ passenger side under carpet..I wouldn't immediately change ECU's if i were you. Its expensive and probably not the issue. I would check the ICM in the distributor cap, have a technician with knowledge of multimeter read the resistance between the ICM & ECU. Before all that we replaced the fuel pump which was unecessary, the outcome was slow cranks & it had oil in spark plug cylinders which I replaced. Good Luck
Old 09-30-2011 | 02:49 PM
There's no carpet covering the ECU of a 98 Civic.
Old 09-30-2011 | 02:56 PM
CarmenDA's Avatar
oh behind the kick panel..
ok sorry I'm new to forums and such but how do i get that black button fastener thingie off that holds it down?
I'm not trying to replace it but I saw another site that said to check for codes that come off of a blinking led light. Is that true? Or am I wasting my time?
Old 09-30-2011 | 04:47 PM
You found instructions for a 4th generation Civic. You own a 6th generation Civic. You pull the CEL codes by jumping the service connector. Click the CEL link in my signature.
sbblumhof
05-22-2011 03:25 PM
norman
11-22-2009 10:40 PM
headacheforhonda
11-19-2007 07:55 AM
headacheforhonda
11-16-2007 11:26 AM
mmcpeck
07-18-2007 10:43 AM
