Where am I loosing brake fluid at?
Old 08-06-2009, 10:35 AM
Ed Fisher's Avatar
My bet is on the rebuilt master cylinder not being a good one, as everything else you checked looks ok. A rebuilt unit, if the brake pedal is pushed all the way to the floor while bleeding, can score the new seals and cause a leak due to the push rod having pits from previous water contamination. That is why it is suggested to put a brick, piece of wood, or your other foot beneath the brake pedal when bleeding brakes so that the push rod only sees natural travel. It takes longer, but doesn't score the seals...As MK378 said look for leakage down the booster beneath the master cylinder.
Good luck and please post your findings.
Ed Fisher
Dallas, Tx
Old 08-07-2009, 10:15 AM
honda_farmboy's Avatar
Banned
Thanks for all the advice. I will go unbolt the MC.
Old 08-07-2009, 10:49 AM
Banned
It has a wet spot on the bottom of the seal. I really hate to have to get another MC again. The booster works just fine.
Old 08-07-2009, 10:51 AM
Banned
But for the amount of fluid I added (about 1cm in the MC) I would think there would be a lot more of a mess here. Maybe it's dripping down into the booster?
Old 08-07-2009, 11:25 AM
Banned
OK so I saw something dripping off a spring inside the master cylinder. Guess i'll replace the master cylinder. Here's my question. The booster works fine, I should just go ahead and use it till it quits? A bad booster won't cause a bad MC will it? The booster is really expensive.
Old 08-07-2009, 12:44 PM
No it won't cause a bad MC but when the booster blows out (when you least expect it) you will suddenly lose power brakes, and you will have to press VERY HARD on the brake pedal (possibly using both feet) to make the car stop.
Old 08-10-2009, 07:42 AM
Ed Fisher's Avatar
Default leaking fluid too
FWIW I am going through the same loss of fluid with a new master cylinder (not a rebuild). I think that I have isolated it to the reservoir leaking. I will know more this weekend when I replace the replacement. Sigh. This is not a reman unit btw, but a new one.
Old 08-10-2009, 07:46 AM
Ed Fisher's Avatar
Also, as I think you will see in your pictures above, the seal that fits around the shaft should prevent brake fluid from dumping into the booster. It is far more likely, I believe, to pour out around the mounting flange and down the front of the booster, which has been the case in every master cylinder leak that I have replaced. Brake fluid in the booster would show up as a smoke out of the exhaust I believe. However, I could be wrong about this, it is just a guess.
Old 08-10-2009, 08:16 AM
PrestonEP3's Avatar
There is only one "o" in "losing".
Ed Fisher
08-20-2009 11:47 AM
BrianT
07-05-2006 10:24 AM
larsenracing
02-10-2006 12:35 PM
lilpooh21186
11-20-2005 08:34 PM
Quick Reply: Where am I loosing brake fluid at?
