wheel hub
Old 09-23-2007 | 07:18 PM
1bdazhatch's Avatar
Default wheel hub
hey hows it going,i just bought a 93civic hb,with a b18 b1.the problem is when i took it home and it was making a weird noise in the right tire i took of the tire and the studs were loose and stripped i had trouble taking off the lug nut.the brake caliper only had one screw and the other one was smushed in the top one.im thinking it the wheel hum assembly if it is,is hard to change,or what can i do
Old 09-24-2007 | 07:02 AM
foress_89's Avatar
Default RE: wheel hub
nice ****... Apart from missing nuts and bolts, are the pieces all there? You might only have to get the bolts. Is it in the front or the rear?
Old 09-24-2007 | 01:10 PM
1bdazhatch's Avatar
yeah all the peices are there,it in the pass front.we replace the studs and they got stripped again.
hovo61788
03-05-2008 07:56 AM
tuong
03-03-2008 11:32 PM
95civicvtec
04-09-2007 12:06 AM
HARI.
04-08-2007 06:22 PM
Quick Reply: wheel hub
