wheel bearing question.
Old 06-10-2008 | 04:25 PM
nik005's Avatar
Default wheel bearing question.
y does one of these cost 100 dollars more than the other. and what one would i need to replace wheen bearings in 1995 civic ex coupe. also i have heard i will need to have the wheel bearings pressed in by a shop when i get them, what does that mean and how much is it
heres the link to parts http://www.autozone.com/N,11200168//...eResultSet.htm
Old 06-10-2008 | 05:37 PM
Default RE: wheel bearing question.
If you remove the wheel hub, which contains the wheel bearing, then you can take the hub to a shop where they will press the old bearing out and the new bearing in.
Old 06-11-2008 | 05:06 AM
nik005's Avatar
so which one do i need. is the cheaper one just the bearing and the more expensive a whole new hub??????????
Old 06-11-2008 | 05:37 AM
They're both just the bearing. They are different brands but I really doubt the expensive one is 3 times as good. You can split the difference, an OEM one from a Honda dealer lists at about $75.00.
Old 06-11-2008 | 05:39 AM
When I clicked the link, I found two types of bearings, one for abs and the other for non-abs, which showed a $10 difference in price. Take a screen shot of what you see and post it.
Old 06-11-2008 | 05:40 AM
nik005's Avatar
hey thanks i think i will go that route. u cant really beat stock honda quality
darkangrydragon
04-03-2012 02:37 PM
beloveddoll
12-27-2006 04:38 PM
supradupra
11-09-2006 11:13 AM
POIZN
06-24-2006 11:45 AM
95CIVICUS
12-25-2005 12:18 PM
