what tools are needed
![Default](https://www.hondacivicforum.com/forum/images/icons/icon1.gif)
Depends how bad the screws are in the rotors. You might need it, you might not. Either way, make sure you're using the right size bit (probably a #3) or you could easily destroy the heads of the brass screws.
ORIGINAL: Kolhoznik
It is possible to do without that...I used a screw driver that was bent 90 degrees and that worked perfectly
