What engine do I have?
Hi guys, I just swapped the engine in my honda because my old one was shot. The mechanic got an engine straight from japan. It just says D15B on it. So is that all it is? Or is it D15 something? And does anyone know the specifications on that engine? Here's a picture I took of it, its kinda hard to see but it says D15B on it
http://img261.imageshack.us/img261/9483/newimagem.jpg
They're 3 different d15b's , but we could narrow it down if the mechanic knew what he got the motor out of and if it's FI or Dual carburated and if it has Vtec.
(stolen from wiki)
http://en.wikipedia.org/wiki/Honda_D...81.5_Liters.29
D15B
* VTEC
* Found in :
o 1991-1995 Honda Civic VTi EG4 (Japanese Market)
o 1991-1995 Honda Civic VTi EG8 (Japanese Market)
+ Displacement : 1,493 cc (91.1 cu in)
+ Bore and Stroke :75,0×84,5 mm
+ Rod Length : 137 mm
+ Rod/Stroke : 1.62
+ Compression : 9,3:1
+ Power : 130 hp (96.9 kW, 130 ps) @ 6800 rpm
+ Torque : 103 ft·lbf (14.1 kg/m, 138 Nm) @ 5200 rpm
+ Redline : 7200 rpm
+ Fuel Cut : 7411 rpm
+ Valvetrain : SOHC VTEC (4 valves per cylinder)
+ VTEC Switchover : 4200 rpm
+ Head Code : P08
+ Piston Code: P08-010
+ Fuel Control : OBD-1 PGM-FI
[edit] D15B (3 stage VTEC)
* 3-stage VTEC
* Found in:
o 1995-1999 Honda Civic VTi EK3 and Ferio Vi
+ Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
+ Rod/Stroke : 1.62
+ Compression : 9.6:1
+ Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
+ Torque : 102 ft·lbf (14.2 kg/m, 138 Nm) @ 5300 rpm
+ Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
+ VTEC Switchover : 2500 rpm (VTEC-E) & 6000 rpm (VTEC)
+ Fuel Control : OBD-2 MPFI
[edit] D15B
* Non-Vtec
* Found in :
o 1988 Honda CRX 1.5X (rare)
o Ferio MX (Japanese Market)
+ Compression : 9.2:1
+ Power : 106 hp (96.9 kW, 105 ps) @ 6500 rpm
+ Torque : 95.4 ft·lbf (13.2 kg/m) @ 4500 rpm
+ Rev limiter : 7400 rpm
+ Valvetrain : SOHC (4 valves per cylinder)
+ Fuel Control : Dual Carburetor
(stolen from wiki)
D15B
* VTEC
* Found in :
+ Rod/Stroke : 1.62
+ Head Code : P08
* 3-stage VTEC
* Found in:
+ Rod/Stroke : 1.62
[edit] D15B
* Non-Vtec
* Found in :
[edit] D15B
* Non-Vtec
* Found in :
* Non-Vtec
* Found in :
Take another picture of the engine, zoomed out. If it has a VTEC solenoid (located on the back left side of the head) then the engine's head is a VTEC head.
Now that does not mean it will engage. An ECU for VTEC or other means of triggering/engaging the VTEC solenoid would be required.
Okay well I just took a picture. Sorry for the ****ty quality but its night out right now. I'll take another one tomorrow if you need me too, or can you get out of it if its v tec?
http://mail.google.com/mail/?attid=0...12e6b25523a972
try photobucket.com
