weird sound?????
weird sound?????
i have a 98 civic with 90,000 miles and it seems like only when i acceleate or decelerate i hear almost like a grinding/winding noise going on...its very had to explain the sound and ideas on what it may be coming from? its pretty loud..i can hear it really well inside my car
RE: weird sound?????
Make sure your transmission is full of the proper fluid. Manual transmissions don't have a dipstick, you have to unscrew a plug to check.
It is helpful to have a friend outside the car listen while you drive past/around him or her.
ORIGINAL: mk378
ORIGINAL: my94civic
well first i was going to say of course manuals have a dipstick, but then i noticed you said manual transmissions, but then you say unscrew a plug?? you would be looking in the engine not the transmission?!?
ok now i know what plugs you meant. Though unscrewing the filler plug will not tell you what is in there, only if there is too much as it will come out. and the bottom one will let you know if there is oil in there or not.
ORIGINAL: my94civic
ORIGINAL: my94civic
...unscrewing the filler plug will not tell you what is in there, only if there is too much as it will come out...the bottom one will let you know if there is oil in there or not.
The bottom drain hole is used to drain oil from the transmission, for example if you wish to replace old oil with new.
