Water dripping from dash?
Old 05-29-2009 | 07:27 AM
Take the hose off, then from under the hood push a wire back into the hole in the evaporator box. If this frees up a bunch of water you had (or maybe still have) a clog in the box. You need to first take the box out of the car (which requires removing the refrigerant from the A/C system then evacuating and recharging when done) to take the box apart. So hopefully just pushing a wire in will unclog it.
If the evaporator box is dry inside, like ej6 suggested, consider the possibility it may be rain water leaking in the body somehow.
Old 05-29-2009 | 07:34 AM
BX_Civic's Avatar
This is happening in my car too so ima check it out.
addiction2bass
04-27-2012 06:17 PM
addiction2bass
03-26-2011 04:42 PM
yamahaSHO
06-14-2006 06:36 PM
ashift30
05-10-2006 11:02 PM
snosurfa7
04-14-2006 01:57 PM
