Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
i have a 97 civic ex (d16y8). recently changed the motor. vtec was working before the swap. now limiter kicks in at 5k rpm's. cel code is p1259. replaced solenoid, reset ecu, still getting cel. any advice?
