VIBRATIONS???
VIBRATIONS???
WHEN I AM IN THIRD GEAR AND ON THE GAS, MY CAR VIRBRATES. WHEN I LET OFF THE GAS THE VIBRATION QUITS. ANY IDEAS ON WHAT IS CAUSING THE VIBRATIONS? ONE OF MY FREINDS SAID THAT IT WAS PROBABBLY A DRIVE SHAFT YOLK. COULD THAT BE IT?
RE: VIBRATIONS???
typing in caps is kinda like yelling, thats all.
It could possibly be your motor mounts. When they wear out its pretty much metal on metal and there is alot of vibration. this will probably be your cheapest problem to fix (if you're lucky)seeing as how a new set will run you about $20.
duke
12-21-2004 08:32 PM
