Very High Idle
Old 10-13-2009 | 06:49 AM
islandtuner's Avatar
Default Very High Idle
Hey guys,
This weekend was basically test time for me.
I had experinced bubbling and backfiring after I had my car timed and what not. The mechanic who did it, said that I must clean my TB and make sure that no holes were covered, because this may be causing the bubbling and backfiring. So I took it down and what do ya know, holes were covered. So I put on a new gasket and cleaned it up and now when I start the car she idles at 2000. I removed the connector from the MAP sensor and she drops idle but not that much. What could be the prob?
__________________
Old 10-13-2009 | 06:57 AM
hamorhead's Avatar
also his fitv was cleaned iacv is new and hoses are new
umm pcv valve? intake mani gasket leak?
Old 10-13-2009 | 10:38 AM
either a sensor isnt plugged up or a vacum leak.
have you check your throttle cable and make sure the flap inside the tb is closed all the way.
MrFirewolf1000
03-28-2012 03:40 AM
islandtuner
10-13-2009 06:46 AM
2000 Si Newbi
04-18-2007 04:58 PM
mill$civic
08-16-2006 01:36 AM
mill$civic
12-15-2005 06:27 PM
Quick Reply: Very High Idle
