v-tec
Old 05-12-2010 | 05:23 AM
Revy's Avatar
Default v-tec
i'm wondering if i can put the v-tec module from my 1997 Civic SI to a 1996 Civic DX (American EJ6) The engine in the SI is the D16Y8, where the engine in the DX is the D16Y7
are the D16Y7 and D16Y8 essentially the same engine?
Old 05-12-2010 | 05:24 AM
Search Mini me swap on google, it will explain everything
Old 05-12-2010 | 05:46 AM
The VTEC feature is all built into the cam and cylinder head. The bottom of the engine is the same except you'll need to take the oil restrictor out of the non-VTEC block. Then put the VTEC head on.
Or you can swap the whole engine over. The D16Y7 and D16Y8 are identical except for VTEC. For that matter pretty much any D-series engine will bolt into any 1990's Civic.
After you have a VTEC head or engine in the DX, swap the ECU and run wires to the VTEC solenoid to complete the conversion.
Old 05-12-2010 | 06:33 AM
Revy's Avatar
which is easier, engine swap or mini me swap?
Old 05-13-2010 | 02:02 AM
Revy's Avatar
bump!
Old 05-13-2010 | 02:10 AM
Mini-me is much easier. Remove head, bolt new head on, install P2P ECU, wire up VTEC, perform IACV wiring fix... done.
Engine swap is the same procedure except that you'd swap in the entire engine instead of just the head. And, out of the mini-me you get a brand new headgasket since you have to change it when you remove the head.
HondaEGcoupe
08-09-2009 10:12 AM
Kenneth Ames
20
02-17-2007 10:39 AM
AOL.COM
04-24-2005 12:07 AM
hondabboy
01-10-2005 09:58 PM
89hatch
12-19-2004 03:06 PM
Quick Reply: v-tec
