Turn Signals
Old 06-26-2007 | 03:50 AM
my94civic's Avatar
Default RE: Turn Signals
ORIGINAL: phan10m
They all light up
Why would he go out and buy any?!?
Does the right side flash faster than the left?
What happens when the hazards are on? Does it flash faster than it used to?
Do the lights flash faster, or is it just the dash light?
IDK if you have them there, it doesnt look like it from your sig, but what about the side repeaters (an indicator on the fender, have you checked that light if you have it)
Maybe if all lights seem ok, IDK im just shooting in the dark a little here, but maybe it is the relay that makes the light flash, or maybe a short in the wiring? Have you checked your fuses?
Old 06-26-2007 | 05:06 AM
mxs's Avatar
mxs
you have to actually check with the TURN SIGNALS on, not just the parking lights. those are all 2-filament bulbs, one for the parking light and one for the turn signal. so if you turn on your parking lights it will "look" like the bulbs are all good, when really it's the other filament that is dead.
Old 06-26-2007 | 10:25 AM
phan10m's Avatar
k well it was fast the other day but its fine now and idk why. Im gunna just be changing the bulbs for the hell of it.
Old 06-26-2007 | 10:31 AM
mxs's Avatar
mxs
then it's probably loose wiring somewhere
Old 07-09-2007 | 08:08 PM
phan10m's Avatar
It was fine , then the headlight went out, i got it replaced and now the light is still not flashing correctly.
Old 07-09-2007 | 09:27 PM
danomatic93's Avatar
June 2010 ROTM
Well, if all the bulbs are good, then it might be the flasher itself. It's located by the up by the fuse box. At least it is in the 5th gens.
dlion77
01-23-2010 09:03 AM
rzimmer11
03-09-2005 09:12 PM
burnoutNshootnos
12-25-2004 10:07 PM
cass4403
12-15-2004 11:34 PM
Rollinon17s150
10-20-2004 03:14 PM
Quick Reply: Turn Signals
