Trouble after head gasket replacement.
Last week, my 1991 EX was having starting problems. Every time I turned it over it would rev up then die immediately. I pulled out the plugs and in cylinders 2-4 they were covered in oil. I thought valve seals but since I had the plugs out I went ahead and tested the compression. I got 125 PSI in cylinders 2-4 and 85 PSI in cylinder 1. I went ahead and replaced the head gasket along with the seals. After I got everything put back together, it won't start. It will not even catch. The compression in each cylinder is right around 110 PSI, I have strong spark and the timing is right on. After I try to start and then pull a plug, it is covered in gas and I am not sure if that is normal. I am thinking that it might be an electronic problem. Any help would be appreciated. Thanks!
bmccue1964
04-02-2015 05:25 AM
jpking17
05-26-2014 12:31 PM
martinc98
12-06-2013 08:30 AM
lvo civic
03-16-2006 01:43 AM
