Transmission
Transmission
I have a 94 civic ex with a d16z6 and I plan on doing some mods to the car and wanted to know how much HP can the stcok auto tranmision hold and is there any parts I can add to the Trans to hold more. Yea I know its an auto! Thanks- Loyd
RE: Transmission
First, welcome to the forums!
As long as you aren't doing anything major to the engine, you'll be fine. Now, if you go with forced induction, you're going to want to build up the stock transmission or swap to a 5-speed.
To upgrade the auto transmission, you can replace the stock clutches. For a clutch kit for your car, it'll run you around $180 (Jegs.com).
RE: Transmission
yeah, I think that'd probably help. Honsetly, I don't think the 5-speed swap is that hard; I've heard it can be done in under a day. From what I've heard, the hardest part is wiring up the stuff that used to connect to the automatic shifter. Other than that, it's basically take the old transmission out and put the new one in.
Here's some conversion help links:
https://www.hondacivicforum.com/m_295187/tm.htm - wiring the stuff up
https://www.hondacivicforum.com/m_257645/tm.htm - if you read down the thread, it has a parts list
http://www.honda- tech.com/zerothread?id=1255332 - copy & paste this into your browser and remove the space... H-T shows up as "****" if you type it around here... site rivalry or something.
RE: Transmission
You don't need one. It's easiest to just swap out the ECU, but it'll run just fine with the auto ECU (It'll throw a Check Engine Light,but it still works). If you want to keep your stock (auto) ECU and not throw the CEL, try this link: http://hondaswap.com/~pills/autotomanual.html
slideman99
08-03-2004 06:10 PM
Civic95Blue
07-29-2004 10:09 PM
