Tranny Swap Gone Bad
I just put a maunal transmission in today and when i started it up after putting everything bad on its was running.. so i cut if off and put the wheels back on and droped it on the floor then i notice that i could really select my gears right... its like i can get it in 1st 3rd and 5th.... i tried to put in in nuetral and roll the car back and i cant find nuetral.. i even went under the car and move the linkage myself to try and get it in there... whats going on? plz help i need to fix asap to get to work
RE: Tranny Swap Gone Bad
Disconnect the shift linkage and see if you can find all the gears by moving the control shaft on the transmission. If not you have a problem inside the tranny. Otherwise it is of course something with the shifter.
Need Gone NOW!!!! D1 Tow Hooks, D15B7 swap, DX tranny, GSR Axles, D series linkage, EF B series Link
S240161
11-03-2005 08:35 PM
