tps problems
tps problems
i keep getting tps cel codes. i ve replaced it 3 times now and after about a week it pops up the cel and reads that the tps is bad....low input. would any1 know y they keep burning out on me. i have a skunk2 intake manifold with 70mm skunk2 throttle
RE: tps problems
You'll need to use a multimeter.
-Turn the key to the "ON" position (not running)
-Tap into the middle wire on the TPS and get your readings from there
-With the throttle closed, take a reading
-Open the throttle all the way, take another reading
-Shift the TPS sensor as necessary until you get the proper readings.
You'll need to be between .45 & .50 at Closed throttle, and 4.5 & 5.0 at WOT.
